poknox
- May 10, 2004
- Hephzibah, GA
- 94xlt 4wd
I have a 1994 ford explorer, V6, 4wd , Automatic. I have replaced the EGR valve, EGR pressure sensor, EGR vacum solinoid, and the ect sensor. When I start the engine the check engine light stays out.It will stay out for ever as long as I don't put it in gear and drive it. The check engine light comes on after about 2 miles of driving and will not go out. When I pull the codes the only one set is 332, EGR valve opening not detected. I don't know what else to do to fix this problem.
