rigbyrigz
- February 1, 2013
- NJ
- 2000 MMounty 5.0L V8 AWD
For my 5.0L 2000 Mercury Mountaineer at 200K miles, I got 10 years ago, I am greatly in need of authoritative word on the MAF and IAT issue. That being, is the IAT on this model (year) 100%-always-part-of -->built-in to the MAF?
I'm not mechanical, but I have driveway helpers. Basically, rough driving and frequent P0171 and P0174 codes influenced me to get another MAF - $25 (new, just the sensor no housing or assembly) that matched the pn spec and what the current one looks like - and have them replace it. Checked for air leaks, tears, loose, etc. of course first. Replacement (with proper unscrew bits) went smoothly.
At first the P0171 and P0174 codes went away (several trips and miles of course for historical fuel trim numbers to make them reappear if "pending") and seemed a bit improved, but soon a P0112 (IAT or related wiring) popped up. Checked for loose wire harness and other things, and actually went so far as to order the Fitting IAT part (specc'ed) from Advance.
(Then) On the way to town, it held back at 20mph when I accelerated for a bit, but then freed up. Some normal driving then but twice at 50 as I was giving it gas it instead dropped to 40. When I started it after a stop, it sputtered, and after a few feet, seemed to lurch and stall, so I stopped. After some rest, it actually bucked and sat there shaking upon starting. However, after I disconnected the MAF it was then OK. Sent that new MAF back to the retailer, and re-installed the old one. So, I am back to somewhat rough driving at times and frequent P0171 and P0174. (note: last year replaced O2 sensor and fuel filter, sea-foamed, etc.)
While thinking about the MAF issue, I looked for the installed IAT, and "we/none of US" could find it (on intake tube or near manifold, or anywhere.) I won't mention that the genuine FITTING IAT Intake-Air-Temperature-sensor part I finally ordered from Advance (1 of 2 - the other is a Manifold Intake Air Sensor) has an etched part number on it that corresponds to "MAP - Manifold Air Pressure" sensors. I also won't mention that the ECT Engine Coolant Temperature Sensor (sender?) is often called IAT in the gads of write-ups online I saw while looking at forums and diagrams.
Neighbor "experts" that said "nahh it aint IN the MAF" (when I suggested THAT) were perplexed they found no place FOR the IAT (i bought) or located the (old/current) IAT itself. Lotsa other stuff (senders/sensors) of course seemed possible (as IAT) but "Nahh" on all we checked. (AND) The current(old) MAF seems to have a little window-opening with a fuse-like prong that some say: yeah that must be the built-in IAT (different than the sensor piece of course, to the outside right.) Maybe yes?
Not sure if the returned MAF (after the bucking/stall) had that same window&prong, I think yes. I NOW wanna buy another MAF, to spec, and under $30 if feasible. Ford genuine and name brands get ya up to $300 or so. But no one seems to say OEM and third-party MAFs tend to be crap. I want the right one for my vehicle (in its current state) of course. (I’m thinking remanufd. isn’t a great path.)
Yeah, if there is an IAT problem and IF there is a separate IAT connection location we can find, and find the right sensor to install, I want to do that as well, eventually. But I'm insanely perplexed as to if any MAF to spec I buy ($30 or $300) will (always?) have the IAT built-in for my 2000 5.0L MM model? If yes, of course I don't need(want?) another separate IAT. If no, how do I buy the right MAF and figure this all out without more migraines? THANKS!
