by way of UPDATE -- the enhanced OBD2 scanner & fuel pressure tester not yet engaged, but a newly purchased (Genuine OEM) xf2f-12b579-AA MAF arrived that had the IAT built-in, and seems sturdier material than the earlier one...
...after battery disconnect 30-minute strategies and stuff to fully clear ECU of historical trim data and maybe more, the install was followed by a followed hodgepodge of relearning guidelines involving 10 minute idling, RPM revving intervals, etc. Thereafter seemed to idle smoothly and then took the 2000 Mercury Mountaineer V8 for a test drive:
most of the driving seemed good - normal or better - but of 3 forays into 65-70 mph acceleration pushes, 1 made the check engine light flash... I think 3 times, but didn't stay flashing or lit. Many sources suggest a cylinder misfire is what 3 quick flashes that go away means, and may be related to a half dozen different causes including MAF issues. There's a chance it's just an isolated event that won't repeat and possibly not bear drastic attention.
Of course, need another driving cycle or 2 and perhaps 50 miles distance to see what codes do pop up, although there is some evidence 2-3 driving cycles as ECU / MAF is RE-Learning might make those codes go away if they appear... so I don't think I will do an immediate erase/reset if they appear. Eventually, some OBD2 data or fuel pressure checks may reveal more; will post.
Thanks all.
