koda2000
- September 2, 2011
- x
I'm replacing the upper control arms (2-piece design right side), lower ball joints and sway bar end-links on my 2001 Explorer EB, 5.0L V8, 2WD with Moog parts from RockAuto. Do I also need to purchase the Moog caster camber bolt kit or any other parts to do this job? (assuming nothing else is worn). Tie rod ends are good, wheel bearings will be examined when removed. Right side contol arm bushings look okay. Shocks were resently replaced w/KYB's and tire wear is good.
Thanks!
Thanks!
