  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
How to: Replacing Camber/Caster Bolts
GRNMACHINE
IL
95 Sport 4x4
Thanks for the pics 2000. Slightly off topic but I have been looking for pics of the difference in 95 to 96+ torsion setups. Superlift claims their lift will not work on the 95's as they torsion bar setup is welded to the frame.
dstro
Seattle, WA
'99 Explorer XLT; V6 4.0L
I'm glad I wasn't the only one having a tough time getting the cam bolt out of it's hole. Thanks for the write-up
truant
Nashua, NH
'98 XLT
Wow. I just bought all of the parts to do this job on both sides of the truck from rockauto for ~100+shipping. Wow. That was less than the price for ONE control arm from advance, autozone and sears auto center. Definetly a bookmark to keep.
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Just a tip to all of you doing this. You don't have to cut the bolts, for the back just bend those lines out of the way. A large ratchet and 21mm socket fits over it fine. It needs one hard break with a leverage bar and then it goes around 1/16th each ratchet because there is no room to move. Also on the front one you can break it with a bar and once its broken push the control arm all the way towards the engine and it exposes the bolt for easier unscrewing. Either way they're a bitch because there is no range to move. You just have to get that leverage bar on in the right spot and crack it a tiny bit to get it started.
torqlox
Cape Coral, FL
99' Mounty V8
Just picked up both sides of Moog kit and plan on doing this tonight. I wish there was a drawing online that described how this system works, because it's hard to tell just by pictures. I am sure I will be able to see it once I am under the truck.
Paul Fithian
Long Beach, IN
2007 Job 1 RWD V8 Limited
Also make sure that both bolt heads are next to the shock absorber mount as shown in the first photo of this post.
Why is this important? I had a very hard time removing the stock bolts on the driver side of a 2001 Sport Trac. The ABS lines and fuel return line are in the way. I'd like to install the new cam bolts with the bolt head on the outside of the shock tower to simplify installation.
The camber bolts are torqued to spec and then adjusted per this video:
by turning the bolt heads, not the nuts.
I can see where having the bolt heads on the outside of the shock tower supports would be easier to access for the alignment guy doing the work. Also, the square 3/8" hole in the cams could be accessed from either side for adjustment.
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
As I recall the reason was to have enough room for the torque wrench with a deep well socket to fit on the nut. If you torque the head of the bolt instead of the nut the cams will turn and alignment will not be maintained.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Yes you definitely want the heads towards the shock tower. You have to tighten the upper arms at ride height with the tires on the ground. It would be near impossible to do if the nuts are on the inside.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Also, to perform an alignment requires loosening the nuts and adjusting the bolt head. The nuts need to have the easiest access to do this. If the bolt head is out your alignment guy is going to get upset while working on your truck. It is doable, but very difficult and out of norm for them to encounter that.
You definitely need an alignment right after replacing these.
Paul Fithian
Long Beach, IN
I believe it would be no problem to torque these to spec no matter which way the bolt is oriented.
From the Specialty Products video, the bolts should be torqued to spec before an alignment adjustment is done.
With the 3/8" hole in the eccentric washers, a breaker bar or ratchet could be put on either side and rotate the washers to adjust alignment. No further torquing of the bolts/nuts should be necessary, right?
My plan would be to install these with Loctite on the bolts and advise the alignment shop to only use the 3/8" square hole on the washer to adjust them. Sound right?
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
No
No loctite is needed. Those are nylock nuts.
Unless you have seen it for yourself, the bolts should face the correct direction. I urge you to take the collective word on that. You came here for an answer, it isn't always going to be the easy one.
There is a trick to installing them right. Once you get it, you will smile. I can't actually describe it, but it involves having the washer on the bolt partially, giving yourself enough room and angle through the first hole, to rotate and finagle the bolt and washer right into place. It is only the one bolt which is a hassle, all the outer washers will slip right on once the bolts are in place.
Paul Fithian
Long Beach, IN
I was able to install these on both sides with the bolt heads closest to the shock tower.
But I had to cut 9/16" off of each bolt in order to get them in.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Applause, and congratulations for not cheating. It really will pay off. The only reason I think the extra thread length would ever be needed would be "if" the nuts worked loose and managed to crawl up 1/2" of thread. Even if it did that bolt is not going to just "fall out".
The alignment guy will thank you. Make sure you point it out to him, he'll know you know what you are speaking about under there and give you a great alignment.
Paul Fithian
Long Beach, IN
Thanks Jon.
But I will start out with a DIY alignment using some blocks, a string, and a machinist level. This will cover toe in and camber.
How critical or adjustable is caster on these vehicles?
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
I'm not positive about sport tracs, but explorers of the same year had an adjustable upper control arm on the passenger side. Once the caster and camber are achieved on the driver side, the passenger side can be adjusted for matching caster.
Think of the control arm as a triangle. Now, if the front camber bolt is adjusted inward, this will pull the upper ball joint forward, decreasing caster angle. However, every time this is done the camber also changes. The adjustable upper on the driver side makes it much easier for the tech to achieve matching caster angles side to side, without going from side to side making adjustments over and over again.
Matching caster is very critical if you want the truck to feel like it is tracking straight. More caster on both sides will make the steering wheel return to straight with more force on it's own, so you can imagine how it would feel if the angles were not very close side to side.
The ride height should be adjusted first, side to side using the lower control arm bolt as the reference.
Then the steering wheel should be centered, with the alignment started off a centered steering wheel.
You should be able to get it dialed in close enough for the drive to the shop, but please do drive it to the shop. IFS is very difficult to get dialed in by eyeball and plum bob.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Paul Fithian
Long Beach, IN
Thanks!!!
Paul Fithian
Long Beach, IN
OK, now I am convinced of the orientation of the bolts as described earlier in this thread.
You can't torque the nuts properly to spec unless the nuts are away from the shock tower on both sides.
koda2000
x
I just changed my upper/lower ball joints last week. I just re-installed my OE caster/camber plates/bolts exactly the way they came off. I went to the alignment shop yesterday and they didn't need to replace the OE plates/bolts to set the alignment. I'm glad I did waste the money on adjustable bolts/eccentrics.
J replacing rear end Stock 1995 - 2001 Explorers 5
I Replacing the dash console indicator module Stock 1995 - 2001 Explorers 2
M Replacing o2 sensors and P0153 code Stock 1995 - 2001 Explorers 1
M Replacing just the boots on ball joints Stock 1995 - 2001 Explorers 5
M 03 Explorer Sport XLT - Alernator still not charging after replacing 3 times in 5 days Stock 1995 - 2001 Explorers 18
M Replacing cat. converter on 1995 Ford Explorer 146,000 miles , second owner Stock 1995 - 2001 Explorers 0
C Shift Solenoid pressure when replacing Stock 1995 - 2001 Explorers 6
1 Replacing Fuel Pump in 98 Exp Sport V6 Stock 1995 - 2001 Explorers 2
W Replacing radiator Stock 1995 - 2001 Explorers 8
2 Replacing A TPS With Damaged Screws, How To Stock 1995 - 2001 Explorers 4
B Replacing water pump and? Stock 1995 - 2001 Explorers 6
R Help Code P0117 after replacing parts Stock 1995 - 2001 Explorers 9
Skip Towne Replacing ball joints. Stock 1995 - 2001 Explorers 11
K Inner tie rod has play after replacing Stock 1995 - 2001 Explorers 9
C Replacing headlight lense on 1999 ford explorer Stock 1995 - 2001 Explorers 7
D Replacing Fuel Pumping without Jacking Up Stock 1995 - 2001 Explorers 27
Mitchs07explorer Replacing main rear seal and oil pan gasket Stock 1995 - 2001 Explorers 0
Mitchs07explorer Replacing main rear engine seal Stock 1995 - 2001 Explorers 9
D Replacing Cylinder heads, which ones to get? Stock 1995 - 2001 Explorers 2
A Electrical issues after replacing Shift Tube Stock 1995 - 2001 Explorers 1
B Replacing rear exterior door handles Stock 1995 - 2001 Explorers 1
C Replacing old little lever with BIG new one! Stock 1995 - 2001 Explorers 0
J Questions about replacing gauge cluster Stock 1995 - 2001 Explorers 19
3 Best approach to replacing front suspension parts Stock 1995 - 2001 Explorers 23
S Replacing oil sender question Stock 1995 - 2001 Explorers 4
G Instructions on replacing the rear output shaft seal on xfer case? Stock 1995 - 2001 Explorers 2
E Paper towel sucked into engine while replacing intake manifold gaskets Stock 1995 - 2001 Explorers 10
B Replacing valve cover gasket Stock 1995 - 2001 Explorers 4
M Replacing lower ball joint, does the spindle have to be removed? Stock 1995 - 2001 Explorers 9
Indispensable Explorer Replacing Radiator... Fan won't come off. Stock 1995 - 2001 Explorers 12
V Wanted Replacing EB Steering Wheel Control Buttons Stock 1995 - 2001 Explorers 9
D Replacing headlight bulb on 2001 XLT Stock 1995 - 2001 Explorers 3
B 98 EB 4.0, Finished replacing heater core and now the right signal light is flashing.... Stock 1995 - 2001 Explorers 0
E 1995. Replacing power steering cooler help. Stock 1995 - 2001 Explorers 2
U Replacing wheel bearing assy created new issue Stock 1995 - 2001 Explorers 9
3 Replacing Cam Timing Chain Tensioner on 2000 Explorer 4.0 SOHC Stock 1995 - 2001 Explorers 12
M Replacing the rear hatch / liftgate lock cylinder Stock 1995 - 2001 Explorers 1
D Replacing Freeze Plugs Stock 1995 - 2001 Explorers 1
S Replacing stock 225/70r15s with more common stock 235/75r15s. 2WD. Need advice! Stock 1995 - 2001 Explorers 5
rewind1 Replacing Glass & Brake Lines / Mold Remediation Stock 1995 - 2001 Explorers 12
P Replacing rear window hinges, questions Stock 1995 - 2001 Explorers 2
B Replacing headlight wires Stock 1995 - 2001 Explorers 11
B Replacing Timing Chains, Guides, Tensioners on FORD 2001 EXPLORER SPORT Stock 1995 - 2001 Explorers 10
R Removing and replacing lower control arm Stock 1995 - 2001 Explorers 6
N replacing rear pinion seal Stock 1995 - 2001 Explorers 1
S lessons learned from replacing everything on the front suspension. Stock 1995 - 2001 Explorers 17
G Replacing the passenger side window motor Stock 1995 - 2001 Explorers 4
P Low side a/c valve leaking need replacing? Stock 1995 - 2001 Explorers 5
P replacing heads other MODs while apart? Stock 1995 - 2001 Explorers 8
W Replacing RF SLA axle bearing in the car? Stock 1995 - 2001 Explorers 0
Similar threads
