cd player install 92' xlt | Ford Explorer Forums
cheddizzle
MN
92 XLT
i just tried installing a cd player and i didnt have a harness kit for the speaker set of wires. when i cut off the terminal for the speaker wire i noticed that there was layer of aluminum foil that went around all the wires. the cd player turns on but no sound comes out of the speakers. can anyone help?
did you wire the amp turn on for the factory amplifier?
also not a 911 situation....
Gotta attach the blue (I believe) wire to the blue/white on your new HU harness.
do a search for amp bypass...... this is a well covered issue, but since you cut off the terminal, you'll prolly have to run new speaker wire if you didn't leave enough to hook it back on..
second of all walmart sells the correct adapter kit, its the one that doesn't have the plastic spacers for chryslers and other models, which for most radios you don't need anyway.
I'm pretty sure theres a leftover wire that has to be hooked to the aftermarket radios blue remote wire, which turns on the factory amp which will make it work without bypassing the amp. or you can order the bypass kit from crutchfield, or find a local shop that has it.
I just went through this with my '94 xlt, and I just reran the wires fresh so I could put an amp under the back seat to push my 4 alpine 5x7s. pretty much figure if you utilize the amp, you'll have crappy sound and if you don't use it you'll blow the stock speakers if you listen to it loud, I think it says somewhere on here its like a 10watt system so your 40x4 or 50x4 Head unit will prolly give them a good workout and a short life (keeping in mind they are 13 year old paper cones).
good luck with it.
The amp bypass deals with the amp, in the rear. He cut off the stock connector behind the HU. The bypass is still doable, but is not required to get sound.
