LEAN THE FRONt SEATS BACK THERE SHOULD BE AN OVAL SHAPED PLASTIC COVER ON EACH SIDE, USE A SMALL FLAT BLADE SCREWDRIVER TO GENTALLY PRY THEM OFF, BEHIND THAT SHOULD BE 2 BOLTS AND ITS EASER TO GET THEM WITH AN EXTENTION. BE SURE NOT TO DROP THE BOLTS OR YOU WILL HAVE TO REMOVE THE ENTIRE CONSOLE
ps sorry bout the caps im at work and was not paying attn.
