If you dont have a fan clutch removal wrench set, fan/fan clutch removal is not nessesary. Here are some tips for fast radiator removal:
1) Drain cooling system of course. there is a port on the lower passenger corner of the radiator that, while slow, will drain the radiator and wont create such a mess
2) Undo Fan shrough (2 8MM bolts) and slide it towards the motor over the fan. Leave there.
3) Robo Grip pliers work wonders on the stock radiator clampy-clamp hose fittings. I would go ahead and replace these with traditional style radiator clamps. And since youre in here, change out the upper and lower hoses as well. Being an OHV motor, you want the cooling system in tip top shape.
4)Trans Lines. They can and will turn on you. Hold the bigger tab with one wrench, and apply pressure to the nut with a second wrench. It's not on tight, but may be corroded. When putting them back in on install, apply teflon tape. Every trans line fitting ive ever put back on has leaked. This fixes it.
5) remove the 2 10MM bolts holding the radiator in, push towards the motor slightly, and wiggle it on out. It will catch on the shroud, hoses, fan, your mother-in-law, but it does come out.
Just take your time, accept you will have to clean up coolant off the floor/ground afterward, and enjoy yourself on a job well done with a spanking new radiator
