Jon M
- January 12, 2017
- Mount Pleasant, SC
- 2015 Explorer XLT
I saw this asked somewhere, and I need to replace mine, so I figured I'd write it up.
This "skin" is glued onto the glove compartment assembly.
Pry it off. I'm going to try using the heat gun on the other one, to see if it will be easier. Regardless, the handle must be wedged up, so that the two arms that hold it closed are retracted, or you WILL break them.
Once you have the "skin" removed, you can remove the two phillips head screws to remove the latch assembly. If you need to remove the trim at the top, silver in the picture above, you can remove the four torx screws.
Here's the latch, removed.
So, you're not changing the lock cylinder, but the whole latch assembly.
Be careful what you're prying on, as the outer skin is softer and doesn't take it well. That's why I'm going to try heating the other one.
I'm going to just use standard super glue to put it back together. That will be interesting. I'm probably going to have to tape it well to hold it on while the glue dries. There are no screws, or tabs, or anything else holding it in place.
