FazeTronics
- September 25, 2015
- Orlando, FL
- 2015 Ford Explorer
Hello, I have a 2015 Ford Explorer. For about a week the AC blower fan would randomly change fan speeds while driving no matter where I set the speed to with the knob. I looked up the problem where older models had the same symptoms, but couldn't find anything for this generation. It turned out to be the same problem; the fan speed resistor pack or also known as the blower fan resistor. Got the part at he dealer for about $130, and it fixed the problem.
The main issue I had was figuring out where the part was located in the dash. There was no information for this generation. All the older models said it was behind the glove box.
This is correct, but for the 2015 you don't have to remove the glove box, you only have to remove the black kick panel at the very bottom under the glove box and behind the airbag module. Three screws... remove that and it will reveal the blower motor. Behind the blower motor is the fan speed resistor pack, two screws hold it up in the air duct. It was awkward to get in there, but pretty easy.
