srider
- August 21, 2001
- Shawnee, KS
- '94 XLT
I'm changing the lower intake gasket and was wondering if there is anything else I should do while I have the intake off. This is on my 94 with 140,000 miles. I am going to replace the spark plugs, wires, ECT, ACT and radiator hoses while the intake is off. I was thinking about replacing the water pump since it has never been replaced. Is there anything else I should check?
Also, is there any difference between the Ford and FelPro gaskets. Since FelPro makes the gaskets for Ford, I would think they are the same, but I've heard the gaskets are actually different. Anyone know for sure? It seems Ford only sells a kit that has the head, valve cover and intake gaskets together. Since I'm not pulling the heads, I was just going to get FelPro as long as they are the updated ones you can get from Ford.
