reserved50
- April 21, 2005
- 2013 Sport Exploder
I'm on my 3rd flush in 3 months using Redline fluid, and going to keep doing it till I can see thru the fluid. I used a vacuum brake bleeder and a small flexible hose to remove the old fluid and used those Mity-Vac kits with the little reservoir to push the fluid back in, took about 30 min total this way. The temp on the side of the PTU was about 125Celcius with a non contact laser temp gun which was still under the flash point of the Redline oil but was getting close, the temp of the transmission was slightly less.
Friend works for Ford and police models with the external cooling fail often also and its a common problem. Mine has the tow package cooling duct under the front facia so it does help to blow the hot catalytic air away as well as cool the PTU, if I was idling for prolonged periods I would probably wrap the rear cat with header wrap.
There has been talk by www.currieenterprises.com that synthetic fluid will void warranty on their high pinion differentials because synthetic fluid runs cooler but does not pull the heat away from the gears as well as non synthetic from what I remember if someone wants to confirm.
Is the fluid running low then the gears/bearings burn up or are the gears/bearings burning up with dirty fluid? Other manufacturers have a similar setup but they don't burn up the fluid like this design, the one thing I noticed is how high the output shaft pinion gear is above the oil level. Can someone please send a link to oil analysis results of their PTU I'm really curious to what they have to say and their recomendations:scratch: and would be REALLY useful.
