If you have an air compressor and don't mind buying more tools, they sell a kit that goes into your air hammer to take off cooling fans.
You can also go to Autozone or some other chain store and borrow/rent (put deposit down and get it back when you return the tool).
the 3rd option is to use a strap wrench to hold the pulley still...
the air hammer tool is the best option, then its a tie between the strap wrench and the rented fan clutch tool. I don't like the fan clutch tool (rented) since it is used and usually doesn't fit as well as it did new. I got the one i rented to work by using my sledge to change the size of the wrench.. (made it smaller)...
BTW.. just about every first gen X has cracks in the fan. If they are around the hub, it MAY not be as bad as you think. It is metal there, and the plastic does crack. Our has been cracked for over 130k miles. The only reason I'm going to replace ours is that I killed the motor mounts which let the fan hit the shroud. Now the fan blades are different lengths and out of balance. I'm sure the water pump doesn't like that.
~Mark
