  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Charge light is blinking on and off
mikeh
St. Louis, MO
98 XLT SOHC V6
My battery or charge light on my dash blinks on and off intermittently. I don't see any other problems. The engine starts fine and everything works fine. When the light comes on and off I don't see the headlights dim or anything. The light comes on and off pretty quick and keeps doing it on and off while running. The battery is relatively new so I'm not sure what the problem is? Any Ideas? Thanks.
Layinhp
CANADA BEST PLACE ON EARTH
2002 XLT v8
start looking for an alternator.... yours is politly warning you its going to fail verysoon
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
Get the alternator tested right away.. You don't want to be stranded when the alternator finally lets go..
L4CX
East Lansing, MI
96 XLT
Let's say that Hypothetically he just redid his Head gaskets and may have busted off the part of the Connector that holds the connector in place. Would/Could that make this happen too? It was Hypothetically the white connector. :D
mikeh
St. Louis, MO
98 XLT SOHC V6
So if my Alternator goes out will my truck immediately stop working or will I be able to limp home 10 miles on just the battery?
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
It'll run till the battery power is drained to the point that the engine will stall out.
mlowney
Foxboro MA,
2003 explorer XLT
have the altinator tested if it dies and you run down the batt you will be replacing both and getting a tow.
mikeh
St. Louis, MO
98 XLT SOHC V6
So tonight the charge light seemed to come on when I accelerated. When I took my foot off the accelerator the light would turn off.
Does this still point to the alternator for sure? It seems to come on more consistently now.
mikeh
St. Louis, MO
98 XLT SOHC V6
Ok so I went to O'Rielly Auto Parts this morning and had it tested. As the light seemed to be coming on constantly now.
His little tester thing said the alternator was bad.
So I picked up a remanufactured one for $170. Tax and core charge out the door for $200 but I get $15 back.
Looks pretty easy to install. Any tricks I should know about before I start?
Layinhp
2002 XLT v8
its a tight fit if you have the v8 to get the belt off to get at the tensioner its best accesible from underneeth just move the flexable rubber out of the way. other then that its pretty straight forward. hope they got you the right alternator theres 2 different ones 1 is hard to get (black back plate)
bigblockford
cape breton
2000 5.0 ford explorer
i have the same trouble tested the alternator an it is fine turned out to be just the little wire on the back was corroded took it off an cleaned the terminal and now its fine its worth a try.
mikeh
St. Louis, MO
98 XLT SOHC V6
Layinhp called it. Wrong Alternator.
I don't know how they did it but they gave me the wrong one. They changed them in 2004 but I clearly told the guy that it was a 2004. The way to tell the difference is that there is 3 electrical connections instead of two. Mine has a round connection with a nut, A larger rectangle connection and a small square connection. The older Alternator has no small square connection. That's the easiest way to tell them apart. The guy said they switch to the new alt about halfway through 2003.
Oh yeah, And it cost $60 more. Ended up about $250. :(
It's a pretty simple repair. Getting the belt off is a pain. If you haven't changed your belt yet you might as well change it. I had already changed mine before.
Here is the step by step if anyone is interested.
1. Remove neg battery connector.
2. Remove the belt from the alternator. don't unweave it from the rest of the stuff.
3. There is a little air hose in the way which I removed for more room.
4. Remove the three electrical connections being careful not to break the plastic connectors. Get a very small screwdriver and insert it in the end of the connection to pull out so that the connection unlocks.
5. Take the three bolts off that hold the alternator on and pull the alternator out of the truck.
Put the other in reverse order.
One strange thing happened when I went to start the truck. It started fine but the little wrench light was on on the dash. When I pressed the accelerator it didn't do anything. I shut the truck off and restarted it and the wrench light went off and it ran fine. I have no idea what that is?
I'd hate to see what a dealer would charge for this repair. Easy to do yourself.
M Flickering/Interminttent Check System Charge Idicator Light Issues Stock 2002 - 2005 Explorers 6
R Alternators keep failing to charge Stock 2002 - 2005 Explorers 20
K Battery: Best way to minimize charge loss when parked for extended periods? Stock 2002 - 2005 Explorers 35
M Core charge for wiper motors...really? Stock 2002 - 2005 Explorers 13
D 2003 Explorer alternator wont charge battery Stock 2002 - 2005 Explorers 2
C New Battery,New Alternator still no charge but battery guage shows half! Stock 2002 - 2005 Explorers 2
R re-charge ac on 02 xls explorer Stock 2002 - 2005 Explorers 13
M 02 w/rear air - R134a charge capacity? Stock 2002 - 2005 Explorers 1
Z 2002 Ford Explorer ABS light comes on and off pulsating brakes Stock 2002 - 2005 Explorers 0
F Driver Door Electrical Problems, Door Ajar Light Stock 2002 - 2005 Explorers 4
R Light pull to the right while driving on the highway. Stock 2002 - 2005 Explorers 4
S 2002 Expo cooling system boiling and OD OFF light flashing Stock 2002 - 2005 Explorers 11
J 2002 4.6 V8 Engine Stall and Low Pressure Warning Light Stock 2002 - 2005 Explorers 0
N Dome light stays on BUT no door ajar Stock 2002 - 2005 Explorers 3
J Door ajar idiot light won't turn off despite all doors being securely closed Stock 2002 - 2005 Explorers 10
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
0 Check Engine Light Stock 2002 - 2005 Explorers 1
W Flashing Engine Light Stock 2002 - 2005 Explorers 12
D Puddle light Stock 2002 - 2005 Explorers 0
P Flashing Check Engine Light Stock 2002 - 2005 Explorers 13
C Curb light replacement Stock 2002 - 2005 Explorers 2
J 02 EXPLORER 4X4 HIGH LIGHT FLASHING Stock 2002 - 2005 Explorers 2
R Code alarm won't crank. Light blinks twice. Stock 2002 - 2005 Explorers 0
E Brake light switch hard to activate Stock 2002 - 2005 Explorers 2
K 4x4 Light stuck on Low Stock 2002 - 2005 Explorers 12
R Fuel gauge/light issues Stock 2002 - 2005 Explorers 4
E What triggers "Door ajar" light ? Stock 2002 - 2005 Explorers 4
S 2002 Explorer check engine light on problems Stock 2002 - 2005 Explorers 2
R O/D light on and problem with Fuel Pump Stock 2002 - 2005 Explorers 0
E ABS light frustration Stock 2002 - 2005 Explorers 15
E should my drivers side mirror have a puddle light? Stock 2002 - 2005 Explorers 1
S AirBag Light Mean? Stock 2002 - 2005 Explorers 3
M using 4 pin connector for extra brake light Stock 2002 - 2005 Explorers 10
B "05" XLT 230K miles ABS light on but with a kicker!! Stock 2002 - 2005 Explorers 2
C O/D Light Blinking-No Codes? Stock 2002 - 2005 Explorers 12
D Check advance track light Stock 2002 - 2005 Explorers 0
M Break light switch wiring diagram Stock 2002 - 2005 Explorers 5
K ABS Warning Light Stock 2002 - 2005 Explorers 2
A Locked ignition - theft light blinking Stock 2002 - 2005 Explorers 5
9 Check engine light Stock 2002 - 2005 Explorers 6
Y Random battery light and module voltage low Stock 2002 - 2005 Explorers 2
G Normal anti-theft light battery drain? Stock 2002 - 2005 Explorers 1
J Door ajar light on Stock 2002 - 2005 Explorers 6
B flashing 4x4 high light Stock 2002 - 2005 Explorers 0
R Newbie - WI with 03' Ford Explorer XLT 4.6L V8 4x4 - Airbag Light Stock 2002 - 2005 Explorers 0
doug625 Light scrapping/rubbing noise Stock 2002 - 2005 Explorers 4
R 2002 Explorer Air Bag Light Stock 2002 - 2005 Explorers 4
C Battery Light comes on intermittently Stock 2002 - 2005 Explorers 2
M LED-light how-to (Sealights on 2004 Explorer XLT) Stock 2002 - 2005 Explorers 0
P Od light flashing hard shifting and diesel noise Stock 2002 - 2005 Explorers 2
Similar threads
