budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
Whelp, O'Reilys and Advanced tested it and its bad. Went to
the "zone" and had a bad time, they will refund the part price , but my core is gone and they can't give me core money back. (WTF) I had a core when this all started. So, I'm borrowing a car at lunch and going to see the store
manager to get this straight. That being said, I was in a sour mood so
I just took a night off and stayed warm at home. I actually get off early
on Saturday, so I will have sun light to go over the wires again.
BTW:Budwich, what do you mean about grounding during the test
finding the problem? Please elaborate. I can't even see the forest
for all the trees anymore.
No problem with your test as I expect exactly that in way, you did follow the "first" instructions which was to test to a KNOWN ground. However, what the followup test should have been was to find out if indeed there is a KNOWN ground at the alternator. Your testing just shows "good voltages" with respect to KNOWN grounds where you used those points. However, it is quite possible that you have lost your ground on your block or elsewhere since the alternator typically gets its ground thru bolting... that can lose contact with a dirty / oily / rusted bolt mating surface but unlikely. Anyways, of course, you know how to test for grounds... hint: its not using a voltage reading...
PS. IF you don't want to take your dash apart to get at the bulb, just turn your key to on and put a ground on the wire (which ever one I previously indicated) and see if your light comes on.
