tortoisethunder
- February 23, 2007
- Simi Valley, Ca.
- 1999 Explorer Sport 4 X 4
I think those are the codes...anyway it is showing lean system banks 1 and 2. I changed the fuel filter, the codes were thrown again...cleared them then cleaned the MAF sensor. I have not driven very far but so far no codes. By the way the MAF sensor was very clean, but I cleaned anyway. I am going to assume the code or check engine light will come on again.
If this does happen...by checking the threads on this site...I most likely have a leak in the intake manifold?
My question I have a 1999 Ford Explorer Sport 4.0l sohc motor. I am the original owner and it has just over 70K miles. Could I get Ford to cover under warranty...the car is in perfect condition? Any input on how to deal with this would be appreciated.
If I have to do myself, which I am a novice, what parts should I replace when doing this repair if I have the top of the motor apart? What part number of the intake manifold, should I buy the part from ford? Is there a thread on this for the sohc, most if not all of the threads are for the ohc?
Thanks,
Mike
Thanks,
Mike
