Check engine light - code reader UK | Ford Explorer Forums
chrystal
essex uk
2000 North Face
Is there anywhere in the UK (except) Fords that can read codes? My light has just come on, seems to drive ok, just a bit of rough idle now and again. I have cleaned the IAC recently because of rough idle. But need to know codes.
Any ideas?
I bought a cheap OBDII code reader off eBay.
Read my codes fine when the check engine light came on,told me the code which I checked in the book and then cleared it, never has come back since.
All depends what part of essex you're in as I'm in Sidcup, the other side of the Dartford Tunnel.
Rob
Thanks for that - I will have a look. Im near Southend. I seem to be going through the typical list of problems at the moment! - ABS light, blank radio face, rumbling wheel bearing & now rough idle. Should have bought a Jap!!!
Chris
