I have a '04 XLT and the check engine light came on a few days ago. I took my truck to Auto Zone to have them read the codes. The truck runs idle it vibrates/shakes for couple of seconds then goes away. Truck runs good after that but the check engine light still on.
The codes from Autozone read as follows.
1. Cylinder Misfire detected, Cylinder #2.
The probable cause for the misfire - Ignition system fault-spark plug(s),
ignition wire, coil.
Vacuum Leak.
Injector Fault.
High or low fuel pressure.
2. Crank Sensor Condition.
The probable cause. Crank sensor defective, check connector and
wiring to sensor or check trigger wheel for damage.
I think I can check problem number 1. but problem number, where would the sensor be located in 04 explorer?
Has anybody had a problem with this issues.
Thanks for any help.
Vacuum Leak.
Injector Fault.
