sumo509
- March 11, 2020
- Chelan, WA
- 04 Explorer, LTD 4.0 V6
Hi, all. First of all I just wanted to say thank you in advance for anybody who can come up with any answers or has any advice whatsoever. Also, I apologize for the novel and if there are spelling errors because I used talk-to-text.
TL;DR... checking charging system error started happening intermittently, Explorer completely died while driving, replaced battery because I figured why not, turns on but same check charging system light/beep persists, and battery discharges when running.
A few nights ago I was driving around and the check charging system light flickered a few times mostly when I came to a stop. It stopped while I was heading back home so I figured it wasn’t really a big deal.
This made me remember a few weeks back my son had been playing in the Explorer and that caused a dead battery because he left the lights on overnight. The next day I jumped it, let it charge and everything was fine for a few weeks until this started happening. (doubting there’s a correlation..)
Back to the day that this occurred... later that night I was going to and almost instantly it started beeping. It only beeped a couple times so I figured it would be all right to make the trip seeing as how it was only like a 20 minute round-trip. Boy was I wrong...
We made it to Walmart just fine I don’t recall it beeping too much-although I was still concerned. On the way back I can’t recall what went first but essentially the headlights went out the dash went out radio went out etc. etc. until finally the vehicle just plain stopped.
Not knowing what the problem was I called a tow truck and had it towed to my house. I started by testing the battery and it read 8.xx. I went ahead and got a new battery—why I didn’t try to jump/charge the old one, I don’t know. It’s probably still salvageable for all I know but whatever. I figured if $70 would fix my problem, awesome. Obviously it didn’t.
Today I finally replaced the battery and the car would turn over. Bad news is, the check charging system light issue persists. For some reason I figured if I left it on for a while with a new battery that maybe it would somehow fix itself. This was obviously not the case because I checked the voltage on the battery while running and it was draining.
Just some minor details... the positive terminal did have a lot of acid build up so I went ahead and took care of that with battery cleaner and protector when I swapped the battery. Everything looked a little bit better but the positive terminal does still have a little crud on it. (Wondering if this is/was the issue all along... will try a deeper clean tomorrow.)
Lastly, I did a lot of research and saw things about the harmonic balancer, fusible links, and checking the alternator connections. The only thing I’m really able to do with my mechanical knowledge (which is very minimal) was check the alternator connections which looked fine to my untrained eye.
I really don’t know what to do at this point other than to take it in to get looked at. I would really just like some advice on what to ask them to look for so that way I don’t get screwed over for some minor fix. I also know I should have the alternator tested—which I plan on doing prior to going to a mechanic assuming it doesn’t die again along the way.
Thanks again!
Chuck
Thanks again!
Chuck
