Cigarette Lighter Fix | Ford Explorer Forums
CarlPalmer
1997 explorer
My cigarette lighter in my 1997 ford explorer is on all the time. So all my accessories keep running. What I would like to do is install another cigarette lighter that turns off when the ignition is turned off. The problem is that I know so little about wiring that is should truly frighten me. I am sure I can figure out how to hook it up, but I am not sure where to the power lead to.
If all you are looking to do is power a GPS or mobile phone or some other small load, almost any power lead for something that goes on/off with the key will do. I usually splice onto the radio power lead. If you want to power more expansive stuff - lights, amps, big radios, etc - you need to get a professional to take a dedicated line back to a main power point and use a relay that is activated when the key is turned on.
Yeah, the damn GPS doesn't turn off by itself. How dumb is that?
Ok, here is my level of ignorance, never having worked on a car's electrical before. I assume that you just melt the plastic off of a spot on the existing wire and patch in the new wire to that spot, hitting it with something to seal it and some shrinkable coating.
Where can I find a wiring diagram for my truck? I assume a power line is going to be red.
OK, some not good assumptions.
1. Power leads not always red.
2. You don't melt off plastic.
Best if you can get an experienced friend to help you. If not, here is some basic guidance.
Great source for wiring docs:
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
Go to auto parts store and get a 12 volt outlet, some red wire, some black wire, and some wire taps; 18 gauge wire will be fine. The wire taps are little folding plastic things with two channels on each side and a metal piece with two slots in the middle. One of the channels goes all the way across; the other has a plastic stop about 3/4 of the way down it. You lay the source wire in the continuous channel, and the new wire in the other channel, each laying in one of the slots in the metal piece. You then fold the two halves together and squeeze it with a pair of pliers; this pushes the metal slots thru the wire insulation, thus tapping the new wire to the old one inside the plastic shell. No tape, insulation or shrinktube needed on these. Use red for power and black for ground. I put my extra outlet inside the center console between the seats.
As an alternative, you can rewire the existing cigarette outlet in the dash. Use the wire taps to connect a red wire from the chosen switched power feed to the back of the existing outlet's power lead, making sure that you cut the existing outlet power lead wire where it goes back into the wiring harness. Will use the existing ground connection, so only one wire to fool with. Only possible down side - if you actually use the lighter as a lighter, might pull too much current, pop fuse, and silence your radio. Good luck and let us know how it works out for you.
Just pull the GPS from the stand.
This way, you won't find in one day your window smashed and GPS missing.
bobflood
TY TY TY! The wiring diagrams are awesome. I am positive I can find a switched lead with them.
Thanks for the tips on the taps. Never saw one before, and that is awesome!
Naw! I'll just add a new one for the GPS. That way I can plug things into whatever side I want. Switched or not!
Seriously TY TY TY for all your advice. I'll let you know if I end up with a smoking pile of ruble where my electrical system used to be, or I can strut around patting myself on the back because I fixed it myself.
SoNic67
Yeah, I don't mind pulling the darned thing when I go anywhere that I can not eyeball the truck. Wallmart, Docs office, etc. At work I look out my window at it, and at home, well it is in the garage... Just a PITA to remember to keep turning it off.
Woot! Got a new behind the dash and a new in the console 12v accessory plug that is switched with the ignition. TY TY TY guys.
