mac66
- June 20, 2000
- Sterling Hts Michigan
- 92 XLT
I decided to clean the engine with degreaser. Read the directions and covered the electronic ignition, intake and most of the wire connectors. Sprayed the stuff on and then washed it off with a hose. When I started the engine, it would idle but giving it gas would make it deisel, sputter, shake etc.but it still idles fine. I sprayed all the connections and such with wd40, even replaced the plugs, wires etc since that is what I was going to do anyway. Any ideas?
