friend99v8
- January 23, 2009
- Durham NC
- 1999 XLT V8
Hey guys-I recently bought a 99 with the 302 motor, I decided to use a bit of that foaming motor cleaner to try and clean up the motor a little bit, and the 1st time I drove it after using the cleanser I noticed that the transmission would hold 3rd gear for much longer before shifting to OD...when it does shift to O/D it shifts cleanly, but it stays in 3rd far too long, often I have to let off the gas completely to try and 'help' it shift to OD.
It shifted perfectly before I used the cleanser, I've looked over the motor to find any connections that might have come unplugged, but it all looks OK to me, the fluid level in the trans looks good and the fluid is fresh. I suspect a vacuum leak but I don't hear any leaks when the motor is running.
any ideas on this would be appreciated! otherwise I'll take into the shop...
