How to: - Clearing Airbag codes | Page 2 | Ford Explorer Forums
How to: Clearing Airbag codes
Prefix for threads which are instructional.
That would make more sense, and that would also better fit the location given(to the right of the instrument/dash.
So basically the only way to clear the memory from the RCM and turn the airbag light off is to have an expensive diagnostics code reader and plug it in, or know someone who has one?:roll:
Yes, I wasn't sure about that. My 99 Limited has no aide air bags, but the air bag wires still go to the seat. Under the seat right next to where the main wiring goes in, the air bag connector is there. On trucks without the aide air bags, the connect is a special resistor, needed to cancel the air bag light. My module is from a 2000 model truck and the seat connectors are different. I have ordered a 2000 model air bag seat resistor to try to stop the air bag light.
Any update, Don?
I am about to head to Ford to see if my front diff. has been rebuilt, and to pick up some parts Tom S has for me. I'll try the sensor promptly, hopefully I can learn something with just one, my error code points to one seat, not both.
mi im new. hear. i have a 01 edge. 4.0 . auto.trans. 4wd. it shows a code 47. ? help..
ed.
thanks for looking. aerostar man. i think i will re count. the flashes.
ed.
hi have been reading through but i can not find said 2 pin reset jumper thingy by the control module. This leads to my next question where or how do i rest the codes on a 98 ford explorer
I've got a 98 explorer and don't believe it has the two wire reset option, it is only clearable with a code reader. That's how I have reset my airbag light.
If the tool is so equiped. My Matco MD 1000 is so equiped and has dignosed and cleared many issues. All through the DLC.
Bosch scan tool will do it and they will let you know when there is updates
That post was ten years old for what it is worth...
You would think that fixing air bag problems was some sort of trade secret...VERY FEW people will give you information on them. I checked my local parts stores for advice (NAPA, AutoZone, Advance, O'Rielly) The common answer is "take it to a dealer" because people are afraid of setting off the airbag. Unless you short the system out just right, or hit a sensor hard. You should be safe. Just take the common precautions of disconnecting the battery...which can lead to a code 52!
If you have ever ran your trucks battery down, or unhooked the battery to work on something, you might have gotten a code 52 on your airbag light. I couldn't tell you what years this works for, but I know it worked great for my 95 Ranger XLT 4x4 4.0L with Auto trans. I couldn't find this info anywhere! So now I am sharing it with you!
By the way...OBDII scanners cannot clear ABS or Air Bag issues. Totally seperate systems!
I started with a code 12 (loss of power to the air bag system) which turned out to be a blown 10amp fuse in the fuse box under the hood. After replacing the fuse, I had worked on several other things inside with the doors open for hours and ran the battery down with the dome lamp. I then got a code 52 (loss of power to the secondary power source for the airbag which is a capacitor) I have read in several places that this is a very common problem with Ford after a loss of battery power. The solution was to "go to the dealer to have them reset it" Who wants to pay for an expensive dealer fix when you can do it yourself easily.
HERE IS HOW YOU DO IT:
Quoted from Mitchell (my observations after each step)
CLEARING CODES
1. Only intermittent codes and codes that diagnostic monitor recognizes as being repaired may be cleared from memory. To clear codes, cycle ignition OFF to ON. Observe AIR BAG warning light. AIR BAG warning light will illuminate for 4-8 seconds, and flash fault code.
(Comment) Loosely translated - If you dont have the problem fixed, this wont work. Code 52 should clear with this!
2. Locate air bag diagnostic 2-pin connector.
(Comment) This was a fun one. According to the air bag wiring diagram that I also got from Mitchell, the Airbag Diagnostic Connector is located "Right side of Instrument Panel". The only thing I found immediately to the right of the I/P (between the stereo and Instrument panel) was a black computer with 4 connectors which is NOT what I was looking for. I finally found a blog that mentioned the computer for the air bag computer was behind the right side kick panel. Sure enough....there it was. Attached to the side of the diagnostic computer was a two prong diagnostic connector.
3. Connect a jumper wire between diagnostic connector terminals. Leave jumper wire connected until diagnostic monitor tone sounds (about 5 seconds). Disconnect jumper wire. Fault code is cleared.
(Comment) After doing this, I heard the loud tone and it immediately gave a different code, but I turned the key to the OFF position and then back ON after disconnecting the jumper.....NO MORE LIGHT!!! :salute:
YOU THE MAN! Worked perfectly on my 95 Ranger!!!!!
Can someone please tell me where the air bag computer is located in a 2000
Explorer XLT? I want to try the above fix but I did not see the computer when I removed the kick panel.Also someone disabled the airbag light and I need to know how they did it. I just bought the explorer from a dealer and if I find out how he did it there is gonna be trouble for him. When I bought it the ABS and Air Bag light was on.I told him to fix it and Now they're both off but I still get the 5 chimes 5 times audible warning that I have an air bag problem. In other words he rigged it to make the lights go out!
Can someone please help me?
Thanks!
I hav the same problem wth my 97 explorer as wth the 5x beeps... Its so annoying...how do u fix this problem???
