Clunk, Grind, and Groan... Front End Problems | Page 2 | Ford Explorer Forums
Yes, a bad ball joint can fail and come loose. I'd replace them ASAP.
Well, felt like I should add myself to this list...
I basically have two problems:
1. When going over uneven pavement at a moderate speed, the front right side makes a sound like the front left wheel is hitting metal. I think it started when I replaced my front sway bar with a Saleen sway bar. Maybe the front left end link isnt tight enough and there is some play causing the metal hitting sound when the front left tires is going quickly going up and down.
2. This happens only when making a right turn. At a certain point when the steering wheel is turned, there is a rather loud "clunk" noise coming from the front ride side as well. I cant really determine where the noise is coming from. Could be the torsion bar, but if anybody else has any other ideas, please let me know.
Thanx guys
Take care
Quakecom
