V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
I just spent the last few hours under the truck and searching the boards:
There are some intermittant noises coming from the front suspention. (1997 V8 AWD, 114,000mi)
1) "Whoo whoo" coming from front end when braking or coasting to a stop, under 20mph. Usually happens more after long highway trips.
2) Clicking from under vehicle.
3) Clunk on coming to a stop, or accelerating from a stop.
4) Popping noise on coming to a stop, accllerating from a stop, or going over bumps. Doesn't always happen.
I jacked up the truck and all the rubber boots looked OK. (CVs, Tie Rods, Ball Joints)
I tried rocking the wheel, but everything seemed solid. There was only the natural play in the steering rack.
When I rotated the front wheels by hand, there appeared to be a very mild binding at one spot in the rotation. Happened at both wheels.
Also, there is a metallic clink coming from the front driveshaft to t-case area. It only happens when the shaft is started/stopped from turning.
Any thoughs? I'd prefer not to throw expensive parts at it, but saftey is #1 - I can't have a wheel bearing or ball joint fail at 70mph!!!
Thanks,
Aaron
Thanks,
Aaron
