- February 11, 2001
- Red Bluff, Ca
- 1975 Ford Bronco 4x4
My buddy has a '96 4WD and he's getting this clunk while moving in reverse. It's not a clunk while putting it into reverse. It's a clunk after it's engaged and traveling backwards. It doesn't happen everytime. Only about 60% of the time.
We put new U-joints in the rear shaft. Didn't fix the problem.
We noticed some play in his rear shaft so we swapped it out with one I had in the garage. Didn't fix the problem.
It sounds like it's coming from the rear of the truck... behind the transfer case. So now I am thinking it's one of two things.
Either the brake caliper bolt(s) backed out like many Explorers do and it's binding against the wheel sometimes. Or, there's something wrong in the rear end. I think the calipers are the less likely of the two, but it would be nice if it was the problem.
So what do you guys think? We'll puff the diff cover this week and see what we see. This doesn't really sound like a tranny issue, right? It goes into gear, and changes throughout the gears fine.
