Okay,
Try this
1. To check your balljoints jack one side of the front up so that tire is off the ground, then take a bar or a 2x4 and slide under wheel with the end of bar about six inches past inside of wheel, gently lift up, watching for movement in wheel, if you see it has play, have someone do the same as you watch balljoints. Do not stick your head under truck at this point.
2. To check for bad tie rod, or center link jack up one wheel same as before and try to shake wheel side to side, if you have play there you will see movement in the steering linkage.
3. To check radius arm bushings, this is difficult because the bushing may look fine on the outside, you can try to check same as balljoint, but this time put the barunder from the front, like you are trying to pick up the wheel, this will put force on axle pushing the arm back if there is play. Now the bushing may just be hard and not plyable anymore, or the spacer inside may be broke. Either way there is probably a ton of miles on them and they are just wore out.
4. Also check top shock mount, if the bushing is squished down and the bolt is bottomed out, then you will also hear that noise, quick fix, take nut off and add a washer.
5. Lastly when checking all these parts, watch for play in your wheel bearings, you may find a little as you run these checks.
I hope I covered it all.
