ColinM
- November 18, 2005
- Albany, NY
- '92 XLT
I have a 92 explorer with x83k miles on it lol. I had to replace the transfer case motor when I bought it. Have done every single fluid possible, valve cover gaskets...belts hoses, wires plugs...you name it. Everything has been going great, except the balljoints are on their way out. However, now whenever I engage 4wd, it seems to work fine but I get a rhythmic clunking noise coming from the left front wheel? I can hear AND feel the clunking. It sounds god awful, I jacked it up and looked under there, nothing looks loose or hanging down or anything, the balljoints aren't any worse than before...i'm at a loss. Auto hubs? Could the hub being all screwed up make that kind of a noise? Idk, just grasping at straws here....It NEVER happens when i'm just in 2wd, only when 4wd is engaged. It feels like someone is hitting the front left underside of the truck with a sledge...just started happening a week or so ago so I havn't been using 4wd. Anyways, any input would be great!
Thanks,
Colin
Thanks,
Colin
