Code help | Ford Explorer Forums
Code help
FLAMETIP
SAN DIEGO, CA.
98 EXPLORER XLT
So I took my explorer to have the codes read, the codes are P0301 and P0304. I know what they mean I just need help with what may cause this problem. Thank you in advance :chug:
Why don't you share what the codes mean for the rest of us that don't know or haven't seached to look it up..
those are both cylander mis fires cylander #1and #4 check plugs and wires and coil packs
Flametip, the number 1 and 4 cylinders fire consecutively, so you may have a crossfire condition between the two. Try cleaning and re-routing the two wires (if they run side-by-side anywhere, separate them). If this dosen't help, then I'd change the wires and plugs.....
