vskidmoreii
- September 21, 2007
- Clearfield, Utah
- 1997 XLT
I have a '97 XLT with the 4.0L SOHC engine. I am getting an intermittent CEL with a P0153 code. The dealer performed a reflash of the PCM, cleaned the throttle body and flushed the injectors to try to fix this. Left the dealer and 10 miles later - the CEL back on with the same code. I am sure there are no vacuum leaks, engine runs good, starts fine, no driveability issues. I have a scanner and understand how the fuel injection system works. Fuel trims are no more than 5% so I think that's ok. I need to get in I/M tested soon and I cannot get the EVAP Monitor to complete.
Question is - does this code just mean the O2 sensor is getting lazy and needs to be replaced?? And, Will the EVAP monitor pass with this code set??
Thanks for any help!!!!
