Code P0156 and P0442 related | Ford Explorer Forums
Chuckaz
PHOENIX, AZ
1998 SOHC 4x4
1998 4.0 SOHC 4X4 138k miles
I recently changed:
Thermostat housing (leaking very badly)
Plugs
U-Joints
Since the Thermostat replacement the coolant level has remained steady and the "strong" coolant smell is gone, but I still have a slight odor when the truck is warm. I would think that if it was the intake gasket it would have some coolant loss? Could I have bumped the O2 wires while working on the U-Joints? Is P0156 the code given when the intake gasket is leaking?
Could these codes be related or do I troubleshoot them separately?
I need advice as to where to start on this.
Thanks
The first one is most likely a bad O2 sensor on the drivers side behind the cat. The 0442 is an evap leak. It could just be the cap or there is a small leak somewhere in the fuel system.
