Ilikemice
- July 6, 2009
- Midlands
- '99 XLT
Hi all, long time no see!
My US spec 1999 Explorer XLT with the 4.0 SOHC engine started showing a P0171 code. I changed the upper+lower intake gaskets but then it started showing both P0171 and P0174 codes!
After clearing the codes it seems it will come back if I drive reasonably hard (For example overtaking up to 70mph, or going up a hill), but I can drive for a few hours without seeing this.
I've cleaned the MAF, replaced the gaskets, and gave the various vacuum lines a check to see if there's anything obviously torn but it all seems okay.
The next area I was planning on investigating was fuel delivery, and today I got a P0442 at the same time as the other two lean codes. I'd replaced my fuel filler neck as it was corroded enough to have a hole in which is where I've seen the P0442 code before, but haven't seen it since until today.
Could this all be linked to fuelling issues? What can I look at next?
Also is it safe to drive it as it is? I've not noticed any loss of power or anything besides a light ticking noise every few secs, with the A/C off.
Thanks!
Thanks!
