sonik
- May 9, 2003
- Seattle, WA
- '94 XLT
My CEL has started to come on for 5 seconds every 10 mins or so after the truck has warmed up. It has only come on when cruising normally, not at a stop light yet. I scanned for codes, and if I'm reading it right I'm getting 511 and 112. I hear 511 is normal for the Apten chip and 112 indicates the IAT circuit it grounded/above 245 degrees. I tested the IAT at room temp and when the engine was warmed up, and the resistance is where it should be. The voltage to the sensor was 4.7v, close enough to 5.
Should I plunk down $15-25 for a new one or is there something else I should be looking at?
Note that my KKM hasn't arrived yet, so I'm not sucking in much more air if it matters...
