EastoutWest
- July 26, 2010
- Middle of Carolina
- 91 4x4 5spd XLT
I've had these two '91's for about a year now. My goal has been to take the best from each and build one reliable fun/work machine.
Here's the skinny:
- Red one is my daily driver - it's a 91 XLT with m5od and electric 4wd/auto hubs. It has a rust problem (probably driven on the beach for years) and is quite beat up with probably 250k miles and sloppy steering/suspension components. It runs pretty well and the transmission is just fine, but the truck itself is pretty much falling apart from the rust and body damage.
- The blue one is on jack stands. It is also a '91 xlt with the m5od but with manual t-case and hubs. Also has factory towing and limited slip, no significant rust, runs very smoothly and has very little play in the steering. But the transmission is destroyed.
I removed the trans from the blue one and opened it up. One of the main gears was stripped clean and metal shavings filled the oil well. I have already scrapped it. I have set out to swap the transmission from the red one, to the blue one, as well as any superior/newer parts.
Now to the questions:
1. Will the m5od from the red one (mated to the electric t-case) bolt right up to the manual t-case? If not, I assume I can swap the electric t-case with the buttons and 4wd computer...
2. Can I just swap the auto hubs from the red one (caps that come off when wheel is removed) onto the blue one with manual hubs? I want to do so because the autos seem to work fine on my red one and I would prefer to shift into 4hi "on the fly" - say when I come up on some ice or snow. Plus I will not be rock-crawling, just the occasional snow, mud, and sand.
3. After the trouble of removing the first transmission (on my back on a piece of plywood under the raised vehicle), I say to myself, "there must be a better way." Can I pull the engine and transmission as one unit out of the hood opening?
For the third question here are a few qualifiers... I am confident that I can handle removing an engine/trans combo as I have done it several times in other RWD vehicles. I would remove the radiator and anything else between the water pump and the front clip. What I don't know is if there is enough room in the engine compartment to get them out. Or if the radiator support can be removed within a reasonable amount of work. That would be ideal for me as I would not need to lift the assembly as high.
If I have to, I WILL do the swap from underneath, but it would really be nice to be able to remove both engines and swap the trans and replace the clutch and slave cylinder on the ground, and do a few other maintenance/prevention measures, then just slide the new and improved engine/trans assembly back into the blue ex.
I don't have access to a vehicle lift but I plan to rent an engine hoist.
I trust and appreciate your infinite cloud wisdom! When I do this, I will document with pictures and a write-up.
Here's the skinny:
