- March 9, 2018
- Location
- In the sticks!
- Shingle Springs, CA
- 98 Sport, 5spd 4.OHV
- Callsign
- Pack Ratt
Anyone ever have this happen? Temp / Compass module started cutting out intermittently, then failed altogether. Opened it up thinking I had a bad connection or something simple. Then I found a 51-ohm smd resistor rattling around in the console housing. Sure enough, the board was missing not one, but two identical resistors. They appeared to have gotten hot enough to desolder themselves! The one I found metered at 50 ohm, and looking at the board I can see they were connected in parallel to up the wattage but give about 25 ohm to the circuit. This appears to be the power circuit for the VFD.
Naturally I can't locate my assortment of resistors at this time, but some rummaging around provided a 22 ohm, half watt resistor.. soldered that in, reconnected the module, profit. If your Comp/Temp stops working, check for this. Resistors are cheap and easier to find than 20+ year old factory modules.
