V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
I think I may have a headgasket problem on my truck. It's a 1997 with 5.0 V8 and AWD. It has 107,000 miles on it.
Symptoms:
1) Excess white smoke from tailpipe.
2) Coolant consumption
3) tiny bubbles on engine oil dipstick after running. The oil was just changed, Havoline 5w30 with Mobil 1 filter.
4) This just appeared today: VERY milky substance on inside of oil filer cap and oil filler pipe.
5) Intermittant knock on shutdown.
I ran a compression test. (ran engine for 10 min right before 1st cylinder)
Cyl #1: 145psi
Cyl #2: 145psi
Cyl #3: 150psi
Cyl #4: 150psi
Cyl #5: 120psi
Cyl #6: 125psi
Cyl #7: 150psi
Cyl #8: 150psi
Those readings seem OK to me - but obviosuly something is wrong.
How do you guys interpret the problem, and where should i go now.
How exactly is a leakdown test preformed? My compression test kit comes with the ability to put pressurized shop air into the cylinder, and I have a compressor.
I originally had this going in "Under the hood" but think it's better in here.
Dead Link Removed
Thanks a bunch,
Aaron
Symptoms:
Cyl #1: 145psi
Cyl #2: 145psi
Cyl #3: 150psi
Cyl #4: 150psi
Cyl #5: 120psi
Cyl #6: 125psi
Cyl #7: 150psi
Cyl #8: 150psi
Dead Link Removed
Thanks a bunch,
Aaron
