BrutalSlammingMetal
- March 23, 2017
- Saint Louis
- 2005 Explorer Sport Trac
Before I begin I'd like to apologize in advance for any protocol I may be breaking - I have just joined and did some searching.
This question is about a 2005 Ford Explorer Sport Trac. I'll attempt to provide some pertinent details:
The right side timing chain jumped some teeth, chewed its guides up, and blew a nice hole in the valve cover. The tensioner is a little rough but I bought a new one and the new one doesn't appear to function too differently than the used one. On the one hand, I think I could save $40 by leaving the old one in. On the other hand, this seems like it could potentially be a cause of the whole issue. What do you think?
The sprockets on the right side camshaft and rear jack shaft don't look too unusual for having 180k+ miles on them. Same with the chain. But those will be replaced. Was not planning on changing the left side or front timing chain/sprockets. Your thoughts?
We have on pretty good authority that, sometimes when the timing chain goes, it can cause the pistons to damage the valves. So we are trying to figure out if the valves are still good. That finally getting to the subject line of the post: what values should we see when we perform manual compression testing? Yesterday we achieved 10-25 PSI on five of the cylinders but close to 50 PSI on the sixth. After some reflection we realized we need to squirt some oil in the cylinders and redo the tests. But what numbers should we see given the above info? I don't want to rig up the stater or other electric motor to turn the engine over because that would be time consuming, but I suppose I will if it's the only definitive way to test the valves.
Last question for now: what other components should I consider changing while the engine is easily accessible?
This forum has already proven to be very helpful during this project. Thanks for any help or insight you are willing to provide.
- V6 SOHC 4.0L
- 187k miles
- I bought it about a year ago with 180k miles
- The engine has been pulled and is sitting on the shop floor
- I am a novice DIY auto mechanic, so not really an auto mechanic. I do work in a field that requires me to be handy with a wrench
- I can't decide if I'm trying to do this fix for as cheap as possible or not
