91eb4x
- January 10, 2011
- san diego, ca
- 91 eddie
I have a stock 93 4.0 it is possible to turn engine over by hand by grabbing flex plate (motor is out) with the plugs in. is this normal for these small motors or does that mean compression is real low. its only got 100,000 on it and is very clean no leaks present. I know it has some compression but obviously I can't do a full on cranking test cause its not in the truck. I thought about a leak down tester but I don't have one and am unfamiliar with it. like I said it has no leaky gaskets oil looks good and both intake and exhausts valves look clean form the back sides which would say pretty low miles. any help would be appreciated
