PolarBlueIce
- February 5, 2004
- Calgary, Alberta, Canada
- 1998 XL
The middle console in my 1998 XL 4-door is the type that has a diving board lever top (I'll refer to it as "Type A" console). A very stupid engineering marvel, because it was designed to break with the repeated weight of your arm resting on it. Yes, it did eventually snap right off, leaving a sharp piece of plastic behind to cause minor injuries. It also leaves me without an arm-rest, and looks awful. I have found a different type of console (I'll refer to it as "Type B" console) at an auto-wrecker, in excellent condition, that came from what I think is a 1997 XLT 4-door. I'm sure that I've seen this Type B console in my year/model before. I brought the salvaged Type B console to a mechanic, but he was reluctant to install it because it was not the identical (Type A "diving board") console like mine. This Type B console is a full length kind with lots of electrical options (climate control) facing the rear. When we took it out of the old vehicle, it looked like the same floor-track to hold it down as in my X. Anyone know if I can make use of it? I do not want to put in any of the wiring for the air vents, I just want this Type B firm sitting lid, because it is engineered logically, so as to avoid a "lever" that would snap under weight. I have comparison pics of these two types of console at: http://www.pacificislandsinfo.com/xplorer/explorer.htm Email your ideas if you will: taori@tvds.net Thanks, Vincent
