Roeseph
- April 8, 2006
- North Aurora, Illinois
- 1992 XLT
Hello, I recently aquired a 1992 XLT from a family member. I'm trying to repair all the things that were ignored before I took over ownership, and I'm not sure what is wrong with the air conditioner. Before I ask my question, let me give you a little backround history on the A/C system. Last spring, The A/C was blowing hot air, the compressor continued to run, it just didn't get cold. The truck was taken to a shop and converted to r134A in March. The air worked all summer just fine. Now it's a year later, and when I turn the A/C on, the compressor kicks on for about 5 seconds, then stops. after about 10 seconds, it kicks on again, then stops. Over and over. And thats about all it does. According to the paperwork, this is what the repair shop did:
1. suction and discharge
2. remove and replace manifold and tube assembly
3. remove and replace drier and accumulator
4. add refrigerant 134a
5. a/c system dye
6. a/c retrofit kit
I read in another thread that the compressor cycling like that would be an indicator of low refrigerant level. I'm just not sure that applies here because before the conversion, the compressor would run regardless of whether or not there was enough refrigerant in the system. I don't want to add refrigerant if that's not the problem, and mess it up. Would that apply here?
Any insight or information would be highly appreciated. thanks!
Also, if it is in fact a refrigerant leak, is there an easy fix that won't involve me having to completely tear down the A/C system? I can work on my own vehicle, but I've never dealt with an A/C system before, and I don't understand how it all works. Thanks again!
Matt - Illinois
5. a/c system dye
6. a/c retrofit kit
Matt - Illinois
