Coolant Leak - But From Where? | Ford Explorer Forums
TM21fourT3
Connecticut
'94 Explorer Sport
UPDATE :
So I took a pic from a different angle, maybe this will help more. This picture is from looking down from the top, help my phone in a strange place to get it actually. Anyways, someone mentioned it was the Lower Intake Manifold Gasket before, is that what it is for sure?
And would that copper spray make it go away if I just covered everything with it? Thanks.
Hey, so I have a leak on my 94 Sport.
I took a picture from the underneath of it on the ground....the right side of the picture is the driver side of the car. Not sure if it'll help, but you can't really see it from the top view of the engine.
The car still starts up, still runs, just has this leak that bothers me. Also makes a couple of "monster" noises when it first starts up...they go away though. I'm trying to drive it very minimal right now, but it's my only car. So I would love to get it fixed.
Any idea what it is for how to fix it? Thanks guys.
Find the leak first, then fix it. Dont forget to look at the water pump.
Picture didnt load for me but if it looks like the crank pulley is leaking then it is the water pump
See my thread for what can happen if you keep driving it
(Dont drive it)
Its the lower intake manifold gasket, i have the same leak. When i first noticed the leak last year, i bought some liquid copper and put it in the radiator, it sealed the leak, but at the start of this winter it started leaking again, so i'm saving money to replace the gaskets.
^^^ I checked my autozone and the only thing copper leak stop related I could find was a spray, but what you used was a liquid to pour in? Sounds much easier.
UPDATE :
What i used was bars leak liquid copper, i bought mine at O'Reillys for like 8 or 9 bucks. I do in fact know that it is the lower intake manifold gasket, mine is leaking in the same exact spot. I choose not to put more of that liquid copper stuff in, because it does more bad than good, and you risk clogging up the cooling system.
Never Never Never use stop leak
it is a poor substitute for fixing it right
