SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I change my oil religiously...every 3000 miles on my 2002 4.6L. Just force of habit as I'm sure most of you change it at 5000 miles. Anyhow, I just changed the oil at 125K miles and was disappointed to notice the oil drain plug had an oil drop hanging on it. Closer inspection reveals that the back side of the oil pan extending all the way to the block was slightly wet. I guess I should feel lucky as it seems that pretty much every vehicle I every own started to show some oil leakage around 70K-90K miles. Usually around the valve cover.
My questions to you are:
1. Does you Explorer leak oil in this same area and what was your solution?
2. Is the problem likely the rear main seal where the oil is coming from and how to determine this?
3. Could I be so lucky as to re-torque the oil pan bolts in hope that that is the source of the leak?
4. I might be having my tranny rebuilt soon. Would this be a good time to fix the problem?
