Coolant leak from this thing | Ford Explorer Forums
HiImBrian
St. Petersburg, Florida
2003 Explorer Eddie Bauer
I have a coolant leak from what I can only assume is a sensor of some sort. I just need to know what it is so I can replace it. It's on my 4.6L. Here's the video:
http://i1092.photobucket.com/albums...-884B-6C0D3428A489-11886-00000A742BCA4960.mp4
It's a link to a video on photobucket.
Heater shut off; heater bypass valve.
It shuts off the coolant flow to the heater coils.
Thanks! Do you know if there are any curveballs I should watch out for while replacing it or is it as straightforward as I think it is?
Pretty straightforward. Just mark the hoses to make sure you get them back on in the right locations. There may be 4 hoses connnected to this.
Thanks. Tackling it this weekend.
Does any 1 have a diagram of the hose locations for this repair. i have the 4.0 engine. got stuck and bypassed this valve when it broke and forgot where the hoses go/
thanks in advance
Lou
thanks in advance
Lou
It flows into the valve and out directly into the firewall. The valve will be marked with a flow direction.
thanks in advance
Lou
i know on my truck u can see on the hoses stating "engine upper" and engine lower, have the valve pointing upwards and in the right direction and hook up the hoses if there marked
