Coolant level sensor | Ford Explorer Forums - Serious Explorations
RonParise
Ft Myers Fl
2011 Explorer limited
I have posted about the water pump in my 2011 Explorer several times. I proactively replaced the water pump at 200,000 miles Now I’m at 370,000 miles and I’m thinking of doing it again. Or just run it out until it finally fails
Instead I’ve rigged a low coolant level alert. So if the coolant level suddenly drops, a big red light on the dash lights
This is actually my second attempt. The first time I put a float switch in the coolant overflow tank. I tested it every week and it worked until it didnt
This time I bought a “non contact” level detector
Taidacent Non Contact Liquid Level Sensor Contactless Water Tank Water Level Sensor for Tank Water Level Control with Low and High Level Output https://a.co/d/aGNNMdg
The instructions say to glue it to the tank. I used a 24 inch zip tie instead. There is an a screw that can be turned to increase or decrease sensitivity which I played with to get it right
Now if I drain the tank a big red led lights on my dash. With any luck if the water pump fails I’ll have enough time to stop the car before it takes out the engine
I´ve always thought things like this should come from factory. The dumb temp sensor will say everything is fine until suddenly it isn´t. The OK temperature range is so wide it would be great if they put an orange range.
In my case my nose was the sensor, one day I was parking at home (thank God!) and I sensed strong smell of coolant, coolant degas was empty and coolant dripping below the alternator, bang! the water pump. I was lucky thou! Not a single drop entered the engine.
Good luck with the sensor!
View attachment 430464View attachment 430465
what light did you get? I was just researching doing this exact thing
I bought these a while back (Amazon) for another purpose. But that project didnt work out, so now, one of them is in the Explorer.
I just set in front of speedometer. Its not pretty, but it works, Any 12 volt light would do, as long as its bright
yeah, those look to be a bit much....are you running a micro controller off the switch or just switch and the light? Where did you pull key on power from?
Its always on power straight from the battery
Wiring the switch was not intuitive , at least not for me. I found a you tube video that helped me a lot.
