GreaseMonkey1709
- September 13, 2022
- Nevada
- 1998, Ford Explorer, XLT
Howdy all! Did some major work on wife's 1998 Explorer 4.0SOHC, and am stumped...
Couple months back, I did the dreaded timing chain repairs after the guides shattered, and now the car runs amazing! However, I attempted to reuse the apparently garbage plastic thermostat housing, which proved to be a mistake... After 2 gallons of readded coolant later, I ordered a fancy aftermarket aluminum thermostat housing, which has been amazing so far, no overheating at all, and no leaks.
Now here's the weird part... After installing this new aluminum thermostat housing (which came with new sensors, and new thermostat), I noticed the temperature gauge rise VERY quickly to operating temp, within about 30-40 seconds of a dead cold start... It does this consistently, with no change. The upper rad hose doesn't even feel remotely warm yet, once it does this, so I assume the thermostat isn't even remotely close to the claimed temperature yet... A day later, when getting on the freeway on ramp, I got P0117 check engine code, obviously in relation to the temperature sensor(s).
While all this happens, the AC will only blow scorching hot air while sitting still idling, but switches to icy cold when I start moving...
I thought maybe I switched the 2 sensors on the housing by accident when I plugged them in, but came to discover that the harness is actually slightly different between the two, making that impossible (presumably?)
Any ideas?? This car is killing me
