pup5581
- February 24, 2015
- '14 Explorer Sport
Installed the 6000K HID Headlights yesterday evening. Totally plug and play and super easy. Passenger side harness from the car to the Collbulbs Ballast had to be flipped around (as it did not fire up at all). That was the only hiccup. Works perfectly now. Installed in my garage. I used painters tape to mark off the Halogen light line. The HID light line hit it exactly. Put me down as a happy customer. Going to keep the stock bulbs stored in the truck for a while...just to make sure.
I held off on installing the fog lights. If they are just as bright as the headlights I am concerned they will blind everyone in front of me (as they are not focused in a projector housing) and then the true FOG/Nasty weather functionality may suffer.
I think I am going to leave the stock FOG light for a bit and explore other options. Perhaps LED.
I believe the HID H11 bulbs I got for the fogs will fit my 2013 Honda Accord's low beams. If that is the case, I shall be using them in that application.
Seems easy to get stock bulb out no? Take the rubber cap off..twist and your good? Need to take the other two plugs below it out as well?
