Correct U-bolts 4 My Application | Ford Explorer Forums
YAMBIG
Turners Falls Massachusetts
91 XLT 4x4
I have a 91 4x4 X. I am doing an aal. I have done a search for the U-Bolt size that I need. So many people are doing an aal and I did not see an actual size specified. I do know that if you are going to lift your ride (or lower it) you have to be prepared to use a hacksaw every now and then! The minimum length with an aal would be just fine, but I am most worried about the span of the "U" and the largest diameter I can fit through the spring plate. They don't have to fit perfect, they just have to work right.
