Cracked rear
Karl77
Elmer nj
05 sport trac
Recently purchased a 05 Sport trac , and realized when I got it home that the rear axle housing is cracked under neath , has a axle code 42 I believe that’s 4:10 what Can I swap it out with
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
If your axle code is "42", and the year of your vehicle is 05', then the only one you can use is one of the same model year and code, 05', with code "42".
Search "BARELY USED" auto parts, and you may have a salvage yard in your area that is in the network. They offer good used parts, and can search in the "Barely Used" network to help find the parts you need, and some "warranty/guarantee" on the parts (check on conditions first before buying). Unless you know all the "ins/outs" on interchanging parts, it is best to stick with your specific make/model/year of vehcal.
HELMUT RONER
Tampa, FL
2002 Explorer Sport Trac
Cracked to what extent and where specifically is the crack? Is it leaking fluid? Were there any noises while you drove it? Can you post clear pictures of it?
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
03-05 sport trac axles are the same. 01-02 have drum brakes but are otherwise the same.
N2FORD
Kingston,TN
2001 Sport Trac 4wd
I have a 98 Explorer 4 door rear end under my ST, it's a D2 code which is the limited slip version of the 42. It is disc brake and works fine. Might be a cheaper more plentiful option.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Which does work just fine but the sport trac runs a larger rear rotor than the 2nd gen rear rotor. Best bet would be to swap all the brake stuff over from the trac to the 2nd gen rear. That way in the future when you go to the parts store you can tell them what you have and not confuse them.
N2FORD
Kingston,TN
2001 Sport Trac 4wd
True, I just have to remember that but since I have a Explorer V8 in my ST it helps.
swshawaii Tailgate Trim Panel Cracked (Reinforcement Ideas Needed) 2001-2005 Explorer Sport Trac 9
M inmates cracked my windsheild 2001-2005 Explorer Sport Trac 5
J Cracked Bed ? 2001-2005 Explorer Sport Trac 11
P Cracked Tonneau Cover 2001-2005 Explorer Sport Trac 2
E Rear end Help! 2001-2005 Explorer Sport Trac 2
H Rear Disc Brake Conversion on 2002 2001-2005 Explorer Sport Trac 2
P '02 Rear Window Replacement 2001-2005 Explorer Sport Trac 0
E Hi, I need help with my sport trac. My Driver side rear brake light/ turn signal is not working. 2001-2005 Explorer Sport Trac 2
T question about rear breaks 2001-2005 Explorer Sport Trac 4
T Rear main oil seal leak 01 Sport Trac 2001-2005 Explorer Sport Trac 2
K Rear Window Weather Seal HELP 2001-2005 Explorer Sport Trac 0
K notice rear differential leaking 2001-2005 Explorer Sport Trac 9
S Rear differential housing ABS sensor replacement 2001-2005 Explorer Sport Trac 10
M Rear bed bolt nut access? 2001-2005 Explorer Sport Trac 5
KA3NXN Rear brakes smoking 2001-2005 Explorer Sport Trac 1
G Help please, rear window washer, '03 2001-2005 Explorer Sport Trac 0
D Scrapping from rear wheel area 2001-2005 Explorer Sport Trac 3
A Door Lock Actuator Part Front vs. Rear 2001-2005 Explorer Sport Trac 6
D Rear Bearings for 2003 Sport Trac 4x4 2001-2005 Explorer Sport Trac 8
C Rear vent power window help needed 2001-2005 Explorer Sport Trac 10
H Changing trans and rear differential fluid 2001-2005 Explorer Sport Trac 3
J 2003 Sport Trac Rear Quarter Panel removal/installation 2001-2005 Explorer Sport Trac 1
M Rear center window regulator 2001-2005 Explorer Sport Trac 0
M Help with Rear Window Motor 2001-2005 Explorer Sport Trac 0
B Center rear window won’t relearn 2001-2005 Explorer Sport Trac 4
D 04 explorer xlt rear axle assembly issue 2001-2005 Explorer Sport Trac 1
C Passenger/Rear Timing Chain Guide needs to be replaced 2001-2005 Explorer Sport Trac 4
M Rear drivers side door wont open 2001-2005 Explorer Sport Trac 5
J Only getting air from rear vents? 2001-2005 Explorer Sport Trac 7
B Looking for rear end w drums for 02 ST 4x4 4.10 gears 2001-2005 Explorer Sport Trac 2
T Never seen a rear main like this one before... 2001-2005 Explorer Sport Trac 6
O Rear sway bar end links 2001-2005 Explorer Sport Trac 9
L No Speedometer, but no ABS light, is it still the VSS on the rear end? 2001-2005 Explorer Sport Trac 3
S 2005 Sport trac rear parking brake shoes 2001-2005 Explorer Sport Trac 12
koda2000 Rear window issue 2001-2005 Explorer Sport Trac 4
S Rear power window switch 2001-2005 Explorer Sport Trac 0
T Rear wiper and washer not working 2001-2005 Explorer Sport Trac 0
A Rear shackle replacements 2001-2005 Explorer Sport Trac 2
P My rear window is going up and down. I can't get it to stay up 2001-2005 Explorer Sport Trac 1
tlambing Driver's Side Rear Door Seal Part Number 4L2Z26247A51AA 2001-2005 Explorer Sport Trac 0
P 04 Explorer EB 4.6L-Rear Toe Link Adjustment Question 2001-2005 Explorer Sport Trac 0
R How Can You Tell The Difference Between an Oil Pan Lower Gasket Leak and a Rear Main Seal Leak? 2001-2005 Explorer Sport Trac 10
swshawaii Rear Child Seat Anchor Cover Fell Off 2001-2005 Explorer Sport Trac 3
C 04 ST rear shoulder belt anchor help 2001-2005 Explorer Sport Trac 0
C Power Rear View Mirrors 2001-2005 Explorer Sport Trac 8
J Rear-End Driver's Side Sag 2001-2005 Explorer Sport Trac 2
C Rear window question 2001-2005 Explorer Sport Trac 5
S rear brake rotors 2001-2005 Explorer Sport Trac 3
K Main Rear Seal 2001-2005 Explorer Sport Trac 9
T Snapped rear jackshaft attachment bolt Sport Trac 2001-2005 Explorer Sport Trac 3
Similar threads
