cranking issues bronco2 | Ford Explorer Forums
lilredbronco2
valley alabama
1986 bronco2
its a 86 bronco 2 it would crank before we put flexplate in now it wont do anything ive replaced the fuel pump in tank it was shot has new ignition control module new fuel filter new coil pack its getting a spark pretty sure its getting gas why wont it crank im seriously about take it to the scrap yard im tired of fixing stuff and it still not working please help
It's not clear to me what kind of no start you have. Is this the kind of no start where the starter doesn't do anything at all? If so, focus on the starter circuit rather than the engine control stuff.
If the starter is doing its part to turn the engine over, but it won't run, then you need to look at the engine control stuff. First step would be to go from "pretty sure its getting gas" to putting a fuel pressure gauge on it and be sure it is getting gas.
yea the starter is working its throwing me all sorts of problems the fuel pump wasnt kicking on so we ran it to the fuse box like a drag car then the injectors wasnt getting fire we was trying to figure out why and they started working all the time when the key was off vapor locked the motor took the plugs out turned it over and let it dry a few days we unhooked the injectors ran them to the fuse box so they come on when the key switch turns on now dealing with timing issues
