Crankshaft pulley removal trouble | Ford Explorer Forums
cols, oh
93 xlt
I have to change the gasket for the timing chain cover in my 93 explorer and can't get the crankshaft pulley off. I rented a the pulley puller tool from Advanced auto and none of the bolts are the right size to thread into it. Does any one know what size bolts I will need?
I said thanks in the other post on accident. I don't know if you will get it so I will ask the other question here. I will get the bolts today and hopefully get the pulley off but I also need to get the timing chain cover off to replace the gasket because antifreeze is spraying out from there. Two mechanics I talked to said those long bolts snap easily, you wouldn't have any tips on getting those out in one piece would you?
I have never removed my timing chain cover, so I can't offer any experience here. However, at one time I was considering replacing the timing chain just for maintenance, and when I looked at my Haynes manual the oil pan had to be dropped, hence the engine pulled...or raised up...so I ditched that idea. I'm not sure if the pan has to be dropped just to replace the cover and gasket.:us:
Just the four bolts holding the pan to the cover need to be removed and the oil pan gasket cut off in that area. I am just a little worried about the long bolts, I guess I will just PB Blaster it and let it soak for a while. Thanks for your help.
